Hi Troy, normally that is one piece high pressure steel line from output of hydraulic pump. The most common way of installing the spool valves for a front loader was to replace this one piece steel line with a two piece steel line with hydraulic hose fittings on the ends. Some farmers would not pay the $$ to IH for this two piece steel line and would cut a section of of the one piece and braze hydraulic fittings on the ends. The end coming from the hydraulic pump would be connected to a hydraulic hose going to the inlet of the loader spool valves and the outlet would go the the line going into the hydraulic housing. Then the dump line would be connected into the hydraulic filler hole at the rear of the seat.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
