Re: Super C problems STILL
Posted by Pete76NY on December 13, 2010 at 21:25:22 from (66.194.51.226):
In Reply to: Super C problems STILL posted by Idaho Ron on December 13, 2010 at 21:14:02:
Technically they are (6v-12v) interchangeable, BUT a 12v coil will generally have a stamp on it that says "internal resistor"...or not...now in a 12v application I know that if it doesn"t say that you have to use an external resistor. I have never used a coil labled 12v on any of our 6v tractors so I don"t know, but I would assume that you would need to uses resistance in that application regardless.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
