Re: Super C problems STILL
Posted by Dean Olson on December 13, 2010 at 21:34:29 from (76.31.42.124):
In Reply to: Super C problems STILL posted by Idaho Ron on December 13, 2010 at 21:14:02:
Coil's can be 6v, 12 volt needing external resistence or 12v with internal resistence. You need to verify what you have.
As a test bypass the resister and see if it fires.
On a 12v neg ground system the power goes to the + side of the coil then to the distributor.
What is the history on your SC? Did it run before and fail? Did you buy it not running?
