Re: Super C problems STILL
Posted by Owen Aaland on December 14, 2010 at 00:16:00 from (65.165.246.162):
In Reply to: Super C problems STILL posted by mkirsch on December 13, 2010 at 21:14:02:
With the points closed you have a complete electrical circuit that has two resistance units, the resister and the coil. In your case the resistance value is the same for both as shown by having 1/2 circuit voltage between the resistance units. Each unit will draw 1/2 the total amperage of the system. With the points open the circuit is no longer complete. There will be no amperage draw in that circuit. The circuit still has electrical potential of 12.4 volts. Coming from the battery the voltage will be battery voltage up to the point where the circuit is open. From the break in the circuit back to the battery the voltage will be zero.
