Re: Wont Run
Posted by Allan from PA on December 14, 2010 at 05:39:46 from (76.125.180.44):
In Reply to: Wont Run posted by Ray McGinn on December 13, 2010 at 07:12:17:
I had a similar problem with a Case SC. Ran great one day and suddenly ran terrible and could not figure out why. Went through everything, carb, mag, anything I could think of. Finally put in new plugs and has run perfect ever since. Sometimes the easiest solution works. Good luck, Allan.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
