Re: Super C problems STILL
Posted by mkirsch on December 14, 2010 at 06:31:34 from (64.80.108.56):
In Reply to: Super C problems STILL posted by Idaho Ron on December 13, 2010 at 21:14:02:
The wiring for the coil on a 12V negative ground system:
1. ignition switch-->ballast resistor--> + terminal on coil
2. - terminal on coil --> terminal on side of distributor
If you do it backwards you will get a weak spark.
But you said the spark from the coil was HOT, right?
Replace the cap and rotor.
