Re: Farmall 460, gears not meshing right
Posted by Owen Aaland on December 14, 2010 at 08:35:54 from (65.165.246.162):
In Reply to: Farmall 460, gears not meshing right posted by GordoSD on December 12, 2010 at 13:26:47:
Well you got me thinking on the change to the 460 so I went to the parts books to look it up. You are correct that the 460 only calls for the thin washer.
The 560 and 660 started with the same thin washer as the 460 and then changed to the thick one. Both the 350 and 450 used the thick washer so the change came with the 460/560/660 tractors.
