Wow Troy I am in the process of fixing up a 2424 I picked up really cheap that looks just like yours only mine is yellow :(
Mine was leaking really bad from the right brake and found that the differential shaft was missing the snap ring holding the bushing in. Had to do a little filing to get the slot back in the shaft and replaced the o-rings on the bushing. That stopped the major leak, but still have a slight drip coming from behind the plate.
I may have to do the same thing you are doing t fix that and the axle seal.
I think the manual says 17 gallons if you have a front mounted pump.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
