Posted by Idaho Ron on December 14, 2010 at 11:00:37 from (208.98.157.18):
In Reply to: Super C problems STILL posted by Idaho Ron on December 13, 2010 at 21:14:02:
The tractor was running about two weeks ago. I was plowing snow and after it warmed up it was bogging down when I used the hydraulics or when I let out the clutch. I took off the gas bowl and cleaned the screen and drained a little gas out to check for water. I took out the screen in the carb and checked it. When I turned the gas back on gas poured out of the carb So I figured the carb needed rebuilt. I took it to a shop to be rebuilt. When I got it back I put it on and gave it a try. The battery was weak so I hooked it to the charger on boost. That is when the coil got hot and leaked oil.
The tractor has a 1 a wire 12v alternator and a 12v battery. I have a resister behind the dash that drops the voltage to 6.2 volts to the coil. This system has been working for the last 4 years. The starter is original. The distributor was NOT taken out at any time.
I added a new coil, and took the coil wire off the distributor cap. I got good HOT spark there. I plugged it back in.
With the points closed I have 6.2 volts at the + post. With the points open I have 12.4.
I put in brand new points and they are set at .020
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
