Re: Farmall 460, gears not meshing right
Posted by Tod Michigan on December 14, 2010 at 14:08:01 from (69.97.231.84):
In Reply to: Re: Farmall 460, gears not meshing right posted by pete 23 on December 12, 2010 at 14:09:26:
Thanks Pete23 for the reply. I have split this tractor 4 or 5 times this summer. Not fun. So, you think that if the shaft has slid backwards, then I need to replace a bearing? Can you tell me which bearing, and where it is located? And maybe where the tractor should be split to be able to do this. (I can do the rest- ha ha). I guess I don't understand how the bearing can keep the shaft in it proper location, can you explain that as well?
Thanks to all.
Tod Michigan
