Joe, back in the early 1950's when we got our first hay baler it was a fairly heavy Dearborn model with a 25 hp 4 cyl. Wisconsin gas engine. We pulled it trailed by a wagon on which the hay was stacked with an 8N Ford at the time and most of the hay fields were fairly flat. The only real problem I recall was when we got into a wet spot in the field the 8N would get stuck if it was very soft. We would have to pull everything out with chains and another tractor on drier gound. Grandpa upgraded his tractor in a couple of years to a larger tri-cycle front end Ford which was a model with the transmission neutral being in a verticle direction. Don't recall the model number but it was much more capable and shortly there after we went to a PTO driven baler as that Ford had a two stage clutch with quite a bit more hp. There were a lot of IH hay balers in the neighborhood being pulled with Farmall H's which seemed to handle them fine. This post is like a short story but heck that was 60 years ago, Hal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
