Re: Intl 434 - funky hydraulic line
Posted by Jimb2 on December 14, 2010 at 17:33:46 from (99.240.236.11):
In Reply to: Re: Intl 434 - funky hydraulic line posted by Troy Schubert on December 13, 2010 at 20:42:50:
Hi Troy, as Armand said that was usually method to
plumb a loader. Over the years we had 434 with
1501 loader and 384 with 1550 loader and now my
brother has a 3230 with 2250 loader and they all
had a double spool valve with high pressure from
pump going in left side and high pressure out left
side to the hydraulic tank and third low pressure
dump line out the bottom of spool valve to a pipe
T fitting into the filler plug of hydraulic
reservoir behind the seat. The 3230 is slightly
different but still has the three hydraulic line.
The reason for the third line is to allow both
hydraulic spool valves to be operated together, ie
rotate bucket while lowering lower arms.
JimB
