1 - Recommend buy/install a new regulator. Ask for one for any early/mid 60's Chrysler product. (The Autozone #VR706 is good - about $25).
2 - No diode required between BAT terminal and ammeter (the alternator's internal diodes are sufficient...)
3 - If the tractor has its original 6 volt coil a ballast resistor is required. However it's been replaced with a 12 volt coil (usually labelled "no external ballast resistor required" or similar) then it's good as is.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
