Re: injector pump leak
Posted by M Diesel on December 14, 2010 at 23:24:31 from (68.104.127.180):
In Reply to: injector pump leak posted by 400D on December 14, 2010 at 15:44:30:
A 400D certainly has a "lift" pump, mounted right on the end of the injection pump. If the primary pump seal is bad and the seal on the injection pump (other end) is also gone then fuel can end up in the engine oil.
Fuel may or may not be in the oil based on the description. Sounds like hydraulic oil is.
