Re: IH 766 denders
Posted by LarryT on December 15, 2010 at 09:27:37 from (68.35.57.27):
In Reply to: IH 766 denders posted by kennell on December 14, 2010 at 15:59:32:
The original amber flashers were surface mounted under the fender along with a field work light right where the grab handle hole is, and the rear was mounted like a lollipop facing horizontally on the back and inside of the right hand fender some were surface mounted and a left hand was optional. It only had one tail light assembly on the back which wired into the caution light switch. All the lighting was controlled by one rotary mounted on the panel, and if I am not mistaken next to it was the turn signal switch. Hope this helps. LarryT
