Re: Cub WILL NOT FIRE...Tried Everything!
Posted by Brownie 450 on December 15, 2010 at 12:28:12 from (66.43.241.198):
In Reply to: Cub WILL NOT FIRE...Tried Everything! posted by RTR on December 15, 2010 at 11:27:22:
Turn the engine to top dead center on the timing pointer. Or by a finger in the #1 plug hole [on compression]. Take the distributor cap off & see where the rotor is pointing inside the cap. It should be pointing to the #1 terminal on the cap. If you have trouble with this procedure, take a pencil & make a mark on the distributor case where #1 plug wire connection is. Sounds like your rotor isn't lining up with the dist. cap contacts when the points are opening [firing]. Incorrect timing is the issue here.
