Re: sealing a gas tank
Posted by James Rumph on December 15, 2010 at 15:10:00 from (96.27.101.101):
In Reply to: Re: sealing a gas tank posted by rluscomb on December 14, 2010 at 19:40:12:
I had one done ware they cut the tank open in the bottom and sand blast all the inside.
They then weld it up and metal finish it so you can't tell. It is then washed out with some solvent and coated with a special sealer.
It is then put in a oven for several hours to cure the sealer.
They stand behind this process for the life of what ever it goes in.
Not the cheapest way but you will never have a issue again. Repainting of the tank is required that is the only down side.
