Posted by Wardner on December 15, 2010 at 19:09:05 from (4.154.254.210):
In Reply to: 400 3rd hyd valve posted by 1950MFD on December 15, 2010 at 16:31:17:
Well there are a couple of reasons:
1. The first valve in the stack always goes to the rear remotes and it is cheaper to plumb from the back side for that valve. Plus the guys on the assembly line didn't have to cope with the tin shroud.
2. The first valve is different from the other two. It only has two service ports. The opposite side single port is used for the PS U-tube.
3. The back side of the two outside valves are covered with the lever bracket for all three valves.
4. The manifolds for the outer two valves need to exit to the front to simplify the mid-tractor hydraulic outlet position. Those four steel hydraulic lines take up alot of space. Why complicate all that spaghetti with two more ports?
There are probably a few more reasons but those come to mind. Just pull back the shroud and have at it. It shouldn't shorten the remaining time you have left on this earth.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
