Re: sealing a gas tank
Posted by Kendog on December 16, 2010 at 03:26:50 from (67.240.244.134):
In Reply to: sealing a gas tank posted by redFarmallboy on December 14, 2010 at 19:26:14:
Actually the RedKote works great, but you need to knock out the scale first, then (because of the baffles) thin the Kote to 50/50 with MEK. Plug the tank bottom and pour in the RedKote mix, slosh it around and drain. Let dry 1hr and do it again. Now force air through the tank for 48hrs. I"ve sealed two with no issues. The key is to drain well, to prevent the R-K from puddling up inside.
Two thin coats is the key!
