Re: wheel weights attatchment
Posted by mkirsch on December 16, 2010 at 06:01:56 from (64.80.108.56):
In Reply to: wheel weights attatchment posted by realolman on December 16, 2010 at 03:09:22:
Did the weights come off a 400 row crop?
If so they will NOT fit a 300 utility easily.
If they will fit inside the rim and up against the wheel center, you can manufacture something to adapt them and bolt them on.
Originally, IH only intended for TWO sets of weights to be installed. It's right there in the owner's manual. They go on as Randy describes.
If you want to install 3+ sets of weights, I recommend the "reddi-rod" aka "all-thread" or "threaded rod" method...
Use four pieces of all-thread that are long enough to bolt all the weights on at once. Install them with a nut on either side of the wheel center so you now have four solid "studs" sticking out of the wheel center. Slide on the weights.
