Re: Jumping 6v?
Posted by randy hall on December 16, 2010 at 10:00:35 from (209.143.0.64):
In Reply to: Jumping 6v? posted by Faster346 on December 16, 2010 at 07:45:59:
like everyone else said hook + to + and - to-. you can"t have an explosion without a spark. make the last connection as far from the battery as possible. i have done this many many times. if you guys ever watched the tractor starting cart at archbold you wouldn"t be afraid of it. i think they can turn that reostat up to 100 volts the way they can spin those old diesels over.
