Posted by mkirsch on December 16, 2010 at 11:01:17 from (64.80.108.56):
In Reply to: But would it run a?? posted by Bud DeLong on December 16, 2010 at 07:12:34:
You need a MUCH slower tractor than a 460 to run a rototiller, if you plan on doing anything more than fluffing up plowed ground.
A hydro or a tractor with a dedicated creeper gear is the way to go if your breaking up fresh ground. The tractor has to move at a crawling speed with the engine running at PTO RPMs.
The tractor won't hold the tiller back if you pull the TA, so you'll just go walking across the field with the tiller pushing the tractor. Even 1st TA will be over 1MPH anyway, way too fast.
I agree with gene on the plow, though... Go with a fast hitch plow.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
