Re: Replacing Farmall Super C shock
Posted by ScottyHOMEy on December 16, 2010 at 11:06:26 from (64.222.203.67):
In Reply to: Replacing Farmall Super C shock posted by Hayrake25 on December 16, 2010 at 06:47:11:
CaseIHFordNH has the parts, as well as some of the after-market folks.
My experience with that one was that I wrenched the two bolts against each other until one gave. I was able to remove it. With no way to hold that threaded center piece/bushing to keep it from turning inside the rubber, I wound up having to grind off the other bolt head to be able to pry the center -- bushing, rubber and all -- out, to make room for the replacement parts.
