Re: 66 shifter on a 706
Posted by ejr-Ia. on December 16, 2010 at 11:13:32 from (204.11.182.12):
In Reply to: 66 shifter on a 706 posted by Rtkman706 on December 16, 2010 at 07:14:50:
Not with out some modification on the two shifting shafts that go down to the transmission they would need to be shortend plus grinding on the right column suport for the dash to let the shifting shaft clear because it is a larger diameter shaft.You have to besure you get every part from the 66.
