Re: 66 shifter on a 706
Posted by pete 23 on December 16, 2010 at 15:50:33 from (184.12.34.48):
In Reply to: 66 shifter on a 706 posted by Rtkman706 on December 16, 2010 at 07:14:50:
It will work but you might want to do some measuring of the column support as there may be diferent lengths, not sure. What I mean is like an 806 is taller in regards to some of the shift linkages etc. Not sure on the shift column support though. You need that support and the range transmission cover and shift linkages as you will be replacing the the one lever input to two levers. Makes a lot nicer shift pattern.
