Re: 12V Conversion..M vs Super M
Posted by Jay Snyder on December 16, 2010 at 16:07:36 from (99.62.237.252):
In Reply to: 12V Conversion..M vs Super M posted by Faster346 on December 16, 2010 at 14:26:16:
Yes it should work fine. Just remember that it takes longer and more rpm to excite the regulator in a altenator. So at idle a lot of times it wont show a charge. Now you can buy some low rpm alts now. It will make them start much better. Also make sure you get the brackets that fit up under the hood or you will have to cut it. I have done a few of them but mainly I leave them with genny on them and 6 volt but I dont use mine much they are just old show tractors. Good luck not a hard convert just a few things to look out for. Make sure you use a ballest resistor. Also sometimes a electric ignition works better with a 12v conversion. Goodluck! any more questions feel free to ask.
