Re: IH 434 / oil in right side brakes
Posted by Troy Schubert on December 16, 2010 at 16:42:34 from (76.127.220.198):
In Reply to: Re: IH 434 / oil in right side brakes posted by neblinc on December 16, 2010 at 13:46:01:
Hi, Randy -
I"m having trouble getting the cage free from the differential. It slides out nearly all the way, but the outer race of the ball bearing catches on the outer race of the roller bearing and that"s all the further I can get.
I ordered the service manual and waiting by the mailbox until I get it.
Any advice for above problem? Was the root cause of your problem the oil seals?
I think root cause on mine was broken bolts and oil seeping between main differential housing and cage. also, RH axle gasket was compromised along the flat area.
What are you doing for gaskets when you re-assemble? I"m thinking to get sheet stock from McMaster and cut them. Mcmaster P/N 9453K203 Vegetable Fiber Sheet Gasket 1/32" Thick, 36" Width, 5" Length Roll $18.78/pc
