Re: Down pressure on my new Saginaw 3 point?
Posted by Stumpy on December 16, 2010 at 17:04:51 from (70.16.195.186):
In Reply to: Down pressure on my new Saginaw 3 point? posted by Yooper Farmall on December 16, 2010 at 11:36:30:
If your hitch is like the one on my M it will have pins through the upper lift arms. If you remove them the hitch will float. This is a good way of acheiving position control.
When you have the pins in place you will have down pressure. I have found the original Lift All valve is terrible in gaining any sort of control over the hitch where a double acting valve adds a bunch of control.
Hope that helps
Stumpy
