Hmm, don't really have an answer for that, pretty sure the bearings should come out of the cage if that is what is hanging you up.
I had several major leaks from the cylinders on the loader, oil coming from the differential lock, left axle seal had been leaking bad and maybe ruined the tire.
So one thing led to another after I had drained and filled with hydraulic fluid to the correct level the leaks really started showing up.
I bought this tractor non running and had to take the carb apart and replace points, condeser & cap, she runs pretty good but was leaking like heck.
I will probably make my own gaskets, I have sheets of several different thicknesses.
The big gasket on the top housing is still in good shape so I can reuse it.
I thought It was going to be a real bear to pull it off of there when I saw there were already 2 broken bolts but it came off with little effort.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
