Re: Down pressure on my new Saginaw 3 point?
Posted by CNKS on December 16, 2010 at 18:08:48 from (216.144.104.128):
In Reply to: Down pressure on my new Saginaw 3 point? posted by Yooper Farmall on December 16, 2010 at 11:36:30:
If you have the standard hydraulics, you have to replumb them with a 2 way valve and a return to the reservoir, or get the factory "christmas tree" that is plumbed to your existing hydraulics. You cannot use 2 way cylinders without those modifications. You can, however use a vent in the down connection to the cylinder and use only one hose, but it will not give down pressure. You do not want down pressure for the plow or disk and possibly the blade. You can use two way cylinders, but they have to float. The hydraulics on your tractor are not as good as the ones on the 460-up, (maybe the 00 and 50 series, not sure) that allow you to return the implement to its previous position when lowering.
