Re: Pertronix Electronic Ignition
Posted by tempola on December 17, 2010 at 04:08:10 from (75.121.253.176):
In Reply to: Re: Pertronix Electronic Ignition posted by CNKS on December 16, 2010 at 07:57:25:
Wrong bud! those points/condenser were new, and gapped to specs.
I never said there is anything wrong with points!
The only thing I do not like about points is as they wear, the dwell changes, and the spring load on the shaft.
If points are superior to electronic modules,why isn't the industry sill using them?
One thing that WILL burn up an Pertronics unit is failing to use a ballast resistor.
Andy
