Re: Saddle (Pull Rod) Type Starter
Posted by rustyfarmall on December 17, 2010 at 06:14:21 from (209.152.78.140):
In Reply to: Saddle (Pull Rod) Type Starter posted by Mark Hogan on December 16, 2010 at 20:07:52:
No, you do not need a new starter, and no, you do not need any kind of solenoid. All you need is the steering post mounted bracket which puts that push button starter switch right up where you can reach it with your left hand. It mounts opposite to, and uses the same bolt, as the ammeter box.
