Re: 806 Power Steering Question
Posted by rustcollector on December 17, 2010 at 08:59:06 from (67.142.165.22):
In Reply to: 806 Power Steering Question posted by clattermac on December 16, 2010 at 16:07:45:
Changing the filter might get the steering working again for a few minutes or hours depending on how much moisture is in the fluid. The oil/water mix forms a gel similar to mayonnaise that stops in the filter. Modern hydraulic systems do require more maintenance than Farmall M hydraulics. Change the hydraulic fluid and filter, then store the tractor in an insulated/conditioned building and work the tractor enough to heat the oil once a month unless you are willing to keep changing the fluid regularly.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
