Re: Jumping 6v?
Posted by bc on December 17, 2010 at 11:42:35 from (71.158.220.25):
In Reply to: Re: Jumping 6v? posted by Faster346 on December 17, 2010 at 10:59:30:
And it may be just as likely you need a new battery and cables anyway. If you haven't put on new cables in the last 2 or 3 years I would suspect them. You can clean the terminals but they start corroding in under the insulation where you can't clean or see it. Batteries over 2 or 3 years old is the same. Usually won't hold a full charge and you don't notice till in the winter when you really need the amps.
If you put it on the charger and still have cranking problems, then battery time. Just like I'm getting ready to, I put a new battery in the PU and rotate the old but still good to the tractor and still have some trade in value on the 9 to 12 years that walmart will prorate them.
6v batteries have larger posts so you likely will need to replace the cables anyway if you convert. Biggest cables you can get. Most places have 2 guage at at good price and better than 4. Get 0 if you are cranking on a diesel or something with glow plugs.
