Around half the SM tractors used a starter just like a M. All the diesel were 3 bolt but 2 different diesel starters were used. All the SM non diesels with 3 bolt mounting used the pull switch on top. Without going to check I think the pull rod is 1/4 inch diameter. Most gasoline type starters of that general time period used starters that the motor part of the starter will work on a 2 bolt housing. I have a M now with a farmall 300 starter motor bolted to the 2 bolt starter housing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
