The reason for the foot operated switch is to get a more positive contact, more power on the foot than the hand. They apparently figured it took more current to handle the starting task on the M than the H. Thing is they didn't perfect the alignment problem. I have redone a lot of them over the years to make that rod or pedal type push the button straight. It didn't always produce desired results. I changed my own M to H style when I went through the tractor a couple of years ago. When you push that button though you need to give it a good hard push to reduce arcing in switch contacts. Far as the hand pull like a super, well, the new switchs you get are not very well made,(even worse than the hand push mounted type) and when you burn into that stud in starter it is a lot more work to replace stud than just a hand push switch. Have soldered many new ones in over the years.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
