Re: Filled Tires
Posted by Nebraska Cowman on December 17, 2010 at 18:00:02 from (66.252.115.12):
In Reply to: Filled Tires posted by KREdwards on December 17, 2010 at 15:23:48:
Most always if a tire is filled with calcium chloride it will be seeping enough through the vale core to at least leave some corrosion if not wet. It it shows any sign of being wet don't poke it unless you are prepared for a bath. Leave well enough alone and put the cap back on. On the other hand if it all looks dry and clean go ahead and let a little air out to confirm it.
