Re: Saddle (Pull Rod) Type Starter
Posted by D Slater on December 17, 2010 at 18:14:31 from (184.15.35.140):
In Reply to: Saddle (Pull Rod) Type Starter posted by Allan In NE on December 16, 2010 at 20:07:52:
Starter drive housings unbolt from the motor part. If the bushing is good in the drive end of a M starter all needed was to bolt the 300 big end and internals onto the M drive housing. You can also put a pull type starter motor on a M drive housing. As already mentioned, if the M starter is okay and you dont want the push or kick type switch. Cheapest would probably be to just get a starter switch like used on lots of fords and others. Push button switch or key switch with start position on it would be needed to use though. Also the starter switch has a terminal to bypass a coil resistor for starting if wanted. You can get a water proof push button switch that will fit in one of the holes in the hydraulic operating rod support or somewhere else.
