Re: My Observation on 6 to 12 Volt Conversions - Rather L...
Posted by jdemaris on December 17, 2010 at 18:24:18 from (72.171.0.140):
In Reply to: Re: My Observation on 6 to 12 Volt Conversions - Rather L... posted by Randy in NE on December 17, 2010 at 13:18:45:
So, it seems you are saying that if something performs AS designed (regardless when it was designed), it's as good as it gets. I.e., it's all relative. When a 1936 tractor left the showroom floor, it cranked just as well at 0 degrees F as a 12 volt tractor does built in 1970.
If you truly believe that, then it's clear you never measured cranking speed revolutions on a cold tractor with either system. Many old tractors with good working 6 volt systems barely crank 75-150 RPM at 0 degees F. 12 volt systems typically crank 200-400 RPM. That can make a big difference with starting.
Using your reasoning, it has me wondering why on earth the 12 volt system became the norm in modern engineering?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
