Re: Can't get my F-20 to run. Need help!
Posted by RB on July 03, 2000 at 18:42:22 from (63.27.121.174):
In Reply to: Can't get my F-20 to run. Need help! posted by Larry on July 03, 2000 at 14:08:35:
Didi you take the mag off?If so take it back off and turn it around until the coupling will go back in,turn it 180 degrees.You may have gotten it out of time that way.If not take of the valve cover set the no. 1 at TDC and both valves closed.Check and see if the rass part of the rotor is at the no. 1 position on the mag via the cap.If all of that is ok could have a fuel problem.
Post A Followup
: Re: Re: Can't get my F-20 to run. Need help!
