Re: Jumping 6v?
Posted by Dellbertt on December 18, 2010 at 05:00:20 from (209.172.21.74):
In Reply to: Jumping 6v? posted by NDS on December 16, 2010 at 07:45:59:
In a magneto system there is no need to remove battery gnd. I just do it as a precaution.
In a dist. system there is a chance of harming a component so I disconnect the battery ground. Once the tractor is running the generator will provide enough juice to run tractor while you reconnect the battery ground. If you want to test that, disconnect the ground while the tractor is running. If your gen is working the tractor will continue to run. (I know the sparkies think that is not a good way to test gen operation)
Dell
