Posted by challenger on December 18, 2010 at 05:30:34 from (96.255.209.165):
In Reply to: 1950 Cub Oil leaks posted by rluscomb on December 18, 2010 at 01:58:38:
Oil leaks just need to to chased down and assessed for seriousness. Since any gasket or seal is a possible source, only a careful visual examination of the surface castings will lead you to the source. If the leak at the rear of the engine is only visible at the extreme bottom of the clutch housing cover, then you may have a leaking rear crankshaft seal. Before correcting oil leak problems, make an assessment whether the leak is bad enough to justify correcting it. Some leaks are just seeps and minor in nature and not serious problems. Others which are dripping at a steady rate should be addressed since they could result in low engine oil level and more serious engine damage.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
