Re: What is the Attraction?
Posted by Shepherd Bill on December 18, 2010 at 06:20:22 from (64.92.150.78):
In Reply to: What is the Attraction? posted by Mr. Mayor on December 18, 2010 at 06:15:11:
Your wife is probably right but it is odd in a good way. I'm not into restoration as much as just having a Farmall around to use and look at.
Bill
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
