Re: Timing question for an M
Posted by Stephen McCoy on December 18, 2010 at 06:47:29 from (173.27.210.76):
In Reply to: Timing question for an M posted by Docs69 on December 18, 2010 at 06:29:57:
I'm assuming that since you suspect the timing to be off you have had the distributor off recently?
The distributor should have enough rotation available to correct for being off by a tooth. You could try loosening the two bolts holding it in place and rotating it by hand to time it if that's the case.
Otherwise it may be a case of the spark plug wires being mixed up. I've run in to this myself. The drawing in my original manual for my H has an isometric (3D) drawing of the distributor cap showing the location of the plug wires. I found it to be a little difficult to interpret. I felt that a top view of the cap would have been simpler to understand.
just my thoughts.
