Re: My Observation on 6 to 12 Volt Conversions - Rather Long
Posted by John T on December 18, 2010 at 06:56:16 from (66.244.97.31):
In Reply to: Re: My Observation on 6 to 12 Volt Conversions - Rather Long posted by Tom Fleming on December 18, 2010 at 06:38:15:
SMILIN RIGHT BACK TOM,,,,,,,, Yep the cold weather starting difficulties are moreeeeeeee a question of SPARK ENERGY THEN CRANKING RPM I DEFINITELY AGREEE......Its not the slow crank RPM, its that wimpy spark....
With a battery powered coil ignition, especially a 6 volt system on big hard to crank tractors, its NOT so much the slow cranking that hurts you as the WEAK SPARK due to drastic battery voltage drop...... They DO NOT HAVE TO CRANK REAL FAST (as you well point out) but they DO NEED A GOOD SPARK. Thats where the mag shines as the lowered battery (if the tractor even has one) voltage dont matter wooooooo hoooooo
Im almost tempted to go out n hand start my mag equipped JD B, it usually starts the first or second flywheel pull over
Gee this is fun
John T
