This is a very "general" answer only, may or may not help..
Iffffff the distributor is timed correct, if you get No 1 cylinder to TDC on its compression power stroke, the rotor tip should be pointed close to the No 1 cylinders distributor cap internal pick up and the points just breaking open.
IE Id first get the No 1 to TDC on compression power,,,,,,,,,,then insert the distributor in such a manner that the rotor tip is lining up with where the caps internal No 1 cylinder pickup is located, and that should also be where the poinst are breaking open.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
