Re: Intl 434 424 / Clutch Pedal Adjustment
Posted by MJin the UK on December 18, 2010 at 07:41:30 from (86.140.198.69):
In Reply to: Re: Intl 434 424 / Clutch Pedal Adjustment posted by jdemaris on December 18, 2010 at 07:10:28:
Had a lot to do with the 434 tractor clutches but never had your fault. Take the tin cover of from under the clutch and get someone to press the pedal while you shine a torch up the hole and inspect the clutch movement. The PTO clutch may need adjusting per the operators manual. MJ
