F-20 paint color help needed
Posted by JohnG(TX) on July 03, 2000 at 20:11:48 from (216.198.62.61):
I am restoring a 1936 F-20 with a #7 Middlebuster and a power lift. I need to know what color the parts of the middlebuster and power lift were painted. I found dark blue paint on the connecting rod from the power lift to the rocker shaft. I also found some black paint on some of the nuts from the middlebuster. These could have been changed sometime in its lifetime though. I am painting the tractor red (I know it is not correct for this year), but I want to know what color the other parts should be to be correct if possible. I am contemplating painting the whole thing red.
Post A Followup
: Re: F-20 paint color help needed
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
