Re: light switch
Posted by RTR on December 18, 2010 at 11:19:40 from (98.83.136.204):
In Reply to: light switch posted by 135 Fan on December 18, 2010 at 11:07:50:
The 4 position on the older switches like that were as follows: LOW CHARGE, HIGH CHARGE, DIM LIGHTS, BRIGHT LIGHTS
The 3 position switches are as follows: OFF, DIM, BRIGHT
The "Low Charge" and "High Charge" don't have anything to do with the lights themselves, but the charging system. You can use the switch you have, and it will work just fine. There is no need to replace it with a different one, unless its defective.
