Re: light switch
Posted by John T on December 18, 2010 at 11:26:38 from (66.244.97.31):
In Reply to: light switch posted by Dorvan on December 18, 2010 at 11:07:50:
Ill give it a shot:
QUESTION: The switch I'm replacing is 6 volt 4 position. I will replace with a 12 volt but should it be a 3 or 4 position switch?
All you need is a 3 position Light Switch, Off Bright Dim. Youre ONLY turning lights on or off NOT regulating a generator charge Low or High like the 4 position LHBD switch does on Cutout Relay systenms that DO NOT have a full fledged Voltage Regulator. No need for a 4 position LHBD, although it can still be used to turn lights on or off ignoring the Low and High Charge uses.
QUESTION
Can someone explain the differance between the
3 & 4 position switch?
The 4 position LHBD was for systems that used a Cutout Relay (NO Voltage Regulator) so the Low and High positions manually regulated the gennys charge by connecting the gennys FLD to ground for High charge but through a resistor on the switch for Low charge.
The 3 position switch Off Bright Dim was for gennys that used a VoltAGE REGULATOR it controlled lights ONLY not genny low or high charge as the VR did that.
Are wiring an On/Off kill switch for the Mag???
If I missed anything the other fine gents will hopefully add more
John T
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
